Rears and Gears!
Rears and Gears!
I lifted my 96 f150 4wd 300I 6cyl. I put 33" mud tires on it and am wondering what i should do first change my gear ration and if i do what to i was thinking 3.73s because i have 3.55s right now and i dont want to lose to much more on the mpg and i wheeled it the last couple weekends and my low and 4low combo seem to still be a low enough ratio. Or should i get a locking setup for the rear first because i did get stucj between a rock and a stump last weekend where if i had a locker id have easily made it out and if that setup use a detroit or a tracklock, keep in mind this is my daily driver! Thanks a bunch
3.55's are good enough for a I6, considering that it was available with 2.73's. (Not a typo - that really is a "2"). You have stump pulling low end torque and 4lo, that's all you need and do you really want higher RPM's and worse gas mileage on the road?
Going from 3.55 to 3.73 is hardly worth it - especially considering you have 2 axles to do. I'd keep the existing gears and just put some kind of posi or locker in the rear.
Going from a 3.55 to a 3.73 isn't worth the time or money. You MIGHT notice a tad more "oomph" off the stoplight, but you'll be running a couple hundred RPM higher all the time with taller gears. 4lo is already giving you a 2.69:1 ratio boost for off-roading, so another .18 turns of the driveshaft really won't benefit you much.
For a daily driver, you want all the MPG help you can get.
I'd go with either a good posi or a locker rear end and skip the gear swap. Both wheels spinning will do a lot more for you in the mud then a little more torque.
