Red Line!
You need to define what you mean by redline
The HP peak is 34-3500 and the auto-trannied versions shift at about 37-3800. If you rev it past 4000 all you're making is noise. If you're setting redline as the maximum shift point, use 4000.
But if by "redline" you mean the RPM where things start to come apart in short order, that's around 6000, if you mean the speed you do not want to exceed, that's probably somewhere around 5000. You pick
