1989 ford 10 or 11 inch clutch
I sometimes buy my clutch kit from autozone and twice from the ford dealer. My autozone clutch don't seem to last as long, but i was looking at the description from autozone and they say its a 10 inch disk. When I called ford they said the only have 11 inch in stock. My question is are these 2 sizes interchangeable?
The F150 came with either a 10.5" or an 11", and either will work. I assume when autozone says a 10", they mean a 10.5"
The 11" will last longer and will "hook up" better, but either one is fine. The 11" has more friction material, so it will wear longer.
It's a Mazda M5OD transmission. The only real weak link is the input shaft, but that won't give you any problems on a stock motor.
