1984 F-150, 351W, Need Pictures
Originally Posted by Kidmet
have a 1984 F-150 I just bought with a lot of vacuum hoses plugged with interesting things like drill bits, pencils, etc... I was wondering if someone could help me figure out what goes where with picturs of their 1984 351W or something similar?
Do you have a California Truck or a 49 state Truck?
What Ignition system do you have? (TFI [EEC] or DS II)
What transmission do you have?
There is a diagram under the hood, but I cannot make heads or tails of it, which is why I was hoping for pictures from someone that has a comparable setup. I was told the tranny was a C-6. It is not a California truck. I don't believe it is EEC (but any easy way to check would be greatly appreciated).
I have a Holley 4-barrel carb. The distributor (vacuum advance, I think) does have the vacuum hose connected. But, with my limited knowledge of Ford F-150s and the fact that these four lines (including one LARGE one) are blocked with drill bits and such, it could be run incorrectly. The truck runs poorly after a stop (usually stalls when i put more than a feather of touch on the gas pedal). It will also stall in turns sometimes. The large hose I am worried about runs under the carb with another smaller hose. (Note: it is not the large hose running from the manifold to the PCV, it's above that but below the carb [or maybe on the base of the carb]) Pictures below.
If you have a vacuum hose going to the distributor then you have the DS II ignition system with a large ignition module bolted to the driver's fender.
I have a 1985 Van with the 351, 4V, C6 like you have but it may have a few changes from what you have. I also have an 83 that came with a 302 that I put a 351 in but I am sure it would not be the same.
The diagram looks like a mess the first time you look at one but it is laid out the same as the truck when new. After you look at it and start tracing lines it will start to get a lot clearer.
If you need any help with the acronyms in the diagram just post back and I will try to explain the item and what the acronym stands for.
The hose runs into a disk like thing attached to the distributor. I don't know if that is what you are talking about, if so, thanks! Yea, I am pretty lost when it comes to the acronyms. I know a few, but not many. The diagram I am looking at is here : http://www1.autozone.com/images/cds/...3d800ce682.gif
Pretty much need a definition of all the acronyms except PCV. Ugh! And the next problem is knowing what they look like under the hood and where they are!
ok, now I am going to sound stupid (which may or may not be true!) but I am still not getting where this is going. I looked at my truck today and didn't see anything like what you are talking about.
The charcoal canister has hoses running to the top of the gas tank and when the tank builds up pressure while the engine is not running the vapor goes into the charcoal canister.
There should be a hose(s) running from the charcoal canister through a vacuum valve to the base of the throttle body. It may not look just like the photo but should be close with a large hose.
When the engine starts and is warmed up a sensor in the engine will turn on vacuum to the valve and with the throttle at mid position the engine will burn the vapor from the charcoal canister.
