'95 F-150 2WD Payload / Rear Suspension Question
Yesterday I hauled a bed full of green firewood. As far as I could tell it basically bottomed out the rear suspension.
The straight six had no problems pulling the load, even up the big hill to my house, but it got me to thinking. What exactly is the rated payload capacity of these trucks?
Also, is there any kind of rear suspension upgrade that would keep the suspension from bottoming under such a load? I drive the truck on the street with an empty bed most of the time, so I'm not really looking for a huge lift kit or anything. Is there such a thing as just a stiffer spring that wouldn't alter the ride height unloaded, yet keep it from squatting so bad when loaded?
Thanks in advance!
Thanks in advance!
To get the rated payload, go get your truck weighed, then subtract the weight from the GVWR on the door jamb sticker. I'm guessing about 1500#.
The I-6 can pull loads far above the capacity of the chassis.
I started browsing on Summit and saw the airbag systems. For similar money one could get these http://www.activesuspension.com/index.htm
They might not eliminate all of the squat, but seems like they might help. Anybody have any experience with these?
On the airbag route, any suggestions as to the best brands?
On my 94 F150 4X4 I put the rear suspension out of a F350 cab/chassis and also added an add-a-leaf, I honestly forget how many springs are in the rear, I think it is either 7 or 8. I have hauled 4600lbs before, I don't really want to do it again either, the drive train didn't have any issues but my load range C Kumho M/T's (33X12.50X15) where sure showing the weight. I also use the truck for a work truck so I always have around 700lbs of tools, ladders, chains, ect in the bed so it really doesn't ride very bad. But would be over kill for you.
I would suggest airbags also. I have Firestone Ride-Rite bags in the rear of my 04 F150 and love them since you can adjust for the weight that you are hauling.
Originally Posted by ccmac
How hard was it to put the 1 ton springs in, did they bolt right in place, or did you have to change the brakets?
Not only do you need to be mindful of the clutch, the input shaft on the M5OD tranny is its weak link.
I have never had any problems with the input shaft in the M5OD. But I did destroy the output shaft on the tranny and input shaft on the transfer case. Once this tranny goes out I am going to swap in a ZF5.
