What happens when your U-Joints are 186,500 miles old?
It also looks like I am missing a seal between the T/C and the yoke slip. That's the only way I can figure the fluid is getting out. Since I am going to have to remove the driveline again to put a seal in, I am going to replace the rear pinion seal since that is bad too, and I only have to take off one more nut to get to it. After that, hopefully all will be well again. Did this outside last night while it was about 33 deg. and snowing hard.
I don't have a vise, that would have made it easier. I prefer the greasable ones too, which is why I got them again. I just have to flip the rear one around when I take it back off to put the seal in. The grease fitting is turned facing into the u joint cradle(?) on the rear end. It was a major PITA to grease it.
I grease every LOF too! I have parts on the front suspension that have to be greased as well, so while I'm under there...
