suspension help
suspension help
Hey guys, haven't been on here for a while but have a problem with my 95 reg. cab F-150. 302 V8. When starting off and slowing down to a stop, the rear end seems to "wallow," or act like I have a flat tire. There is a slight vibration at highway speeds. No flats, can't seem to see anything with the shocks. Don't drive it rough, its my daily 62 mile round trip driver. 100k on odometer. Guess you could say it has a slow wiggle from seems like the rear end more than the front end. Any help would be greatly appreciated. Thanks.
Check the leaf spring mounting brackets. On my old '93 I had a similar symptom, and the front leaf spring mount brackets were broken, allowing the leaf spring to jiggle around.
But carefully check the tires as well. Either jack one wheel (if it's a peg-leg axle) and put it in N, then slowly rotate the wheel. Otherwise, get a helper to slowly inch the truck along while you examine the wheels. All sorts of stuff can get stuck in tires and cause vibrations. Also note the tread for any uneven wear.
Have your tires been balanced recently?
