302 engine
302 engine
I have a '96 with the 302 engine in it. It just hit 60,000 miles and I haven't had to do anything besides replace the starter. With that, is there anything I can do to the engine to tune it up and make it run better? Don't have a whole lot of cash so i'm not looking to go with headers yet, but are there other options? any help or comments would be great.
Doggone - that is unbelievably low mileage for a '96. The 302 is a solid, reliable, proven engine. For your vintage, it delivers a reasonable amount of performance.
Suggest to make sure it's performing up to spec - no computer codes thrown, check the things F151 recommended - especially the filters, and you should be good-to-go for a long, long time.
Assuming the 'check engine' lamp is good, then an occuring fault should light it up. A stored fault that has occured in the past but is no longer in a faulted condition will not.
I always pull codes first whenever there is an operating problem - has helped time and again with pointing in the right direction - what is wrong, as well as what is not wrong.
Is there really any advantage to the oils labeled as "high mileage? I've been using them in my 351 with about 128k, though the motor ran perfectly fine when I bought it at about 120k. Top end was rebuilt at 100k. It still uses about 1 quart over 3000 miles, which seems pretty normal considering age and that it was used to tow a 40' RV quite often for most of it's life.
I guess I'm one of those people, that if it ain't broke, dont fix it.
Regards,
Max
For some cheap power gains, get yourself a MSD coil, cap and rotor and the Ford Racing 9MM wires and some cheap Autolites gapped to 0.055". Bump the timing to 13.5* and run with it.
Change all fluids and keep em clean. Change all filters.
The next step would be headers and a free flowing exhuast.
Hi
With 370k on a 1995.
Keep it clean so you can see any leak.
My story: a small (1970 standers) gasket leak ended up:
sensors replace, (3)
vave gasket replaced,
Harmomic balancer replaced,
cat replaced (BOTH)
IN the past year (took 1year to clear the problems).
Total cost about 3.5k, last year, did ac hoses also $350?
A good shop would have said what would have happen with the oil leak.
having seen the truck at a min of 3 times in the previous yr
I will never go back to them (It is a ford shop)
also:
every year I go to ford for a 30k checkup (do it all)
I DRIVE 30K YEAR
after 2 heater cores, 2 radiators, cooling system hoses 4 times.
Many years trying to resolve the cause of the problems with ford.
advice:
1)do not depend on anyone else,(they do not pay the bill).
2) Change the expendables, (oil,coolant, trans, ect).
coolant and transmission at a min of 30k, max coolant, 1yr "cheap"
trans max 30k, (trans -x works great, could not find 1 mo ago ?).
3) FIND A CAR MECH YOU CAN TRUST(""""""" MOST INPORTANT POINT """""""""")
4) FIND A CAR MECH.
5) FIND A CAR MECH.
GET THE POINT.
THE CAR MECH CAN COST OR SAVE YOU $1MILLION
IN YOUR LIFE TIME, MINE DIED 4 YEARS AGO.
NOW I HAVE PROBLEMS, IT TAKES TIME FOR PROBLEMS TO BUILD UP.
I do not know when an engine is "worn out".
1964 50k to 80k miles, rebuild, (blue smoke).
I am A 1943 baby, (keep things,)
My son could go throught an engine in 5k ( 1 set of tires)
I hope this helps
old100
cat replaced (BOTH)
also:
I DRIVE 30K YEAR
advice:
4) FIND A CAR MECH.
5) FIND A CAR MECH.
GET THE POINT.
I hope this helps
old100
