Electrical issue
Electrical issue
Does anybody have a good schematic for a 91scab.My problem is there are two fusible links that are yellowish tan coming off the solenoid one is thicker than the other. Attached to the thinner one are 2 dark blue lines that also appear to be fusible links.A.Where do they go and what do they power?B.If you know what they are for is there any current draw from that line in key off position?I am getting a slight draw in key off by disconnecting the ground wire and running a test light between batt and wire.I appreciate any and all information or an educated guess.I hate electrical problems as they can be bitch to figure out alone.P.S. batt was dying every couple of days had alt and batt checked OK.Again any help is greatly appreciated. Thanks ,Anthony
