Starting Problem
Starting Problem
I have a 93 that has a issue. I hooked up a switch to manually turn on the electric fans and inadvertantly crossed wires. The fuse panel slot where I ran the hot lead is no longer hot (the fuse didn't blow) and the truck no longer starts. The engine turns over but no go. Any ideas?
Originally Posted by taxabel
How do I find the blown fusible link? I have looked around and at the wiring and nothing seems toasted.
Not sure what would cause you to blow other fuses as well in the box.
I'd say maybe find a schematic for the fuse box to see where the wires lead to. Could lead to the same place at one end for the other fuses you blew.
