89 signal light problems/need to troubleshoot signal light switch
I tried this question in the electrical section with no luck.
On my 89 F-150 the left front signal won't flash. The rear left works fine. I used a test light on the wires comming from the signal light switch. The wire going to the working left rear flashes. The wire going to the left front won't flash the test light. Also the horn only works with the key off.
Could I assume the signal light switch is defective?
