Bypassing the smog pump
Is it even possible with just a shorter belt? I haven't really looked at the setup on my truck, but I know with my Camaro it requires a pulley to be bolted in place of the pump.
If there is enough room for the belt to work without it though, you could always just do trial and error. Part stores carry just about any length belt you could want, just keep trying until one fits right.
Why do you want to do that?
The engine in you truck is designed to run with the smog pump. I doubt it will give you anymore power or mileage. It probably will make them worse.
Retrofitting mid '60s cars with the vacuum advance on/off valve, upon resale, caused performance degradation. Those engines were not designed for smog equipment. Yours is.
Also, why should we breath your excess pollution?
My brother, mother and wife have asthma. Why should we make it harder for them and several million other people based on an urban legend.
-Lance
-Lance
Don't come on here preaching to me buddy. If thats the way you feel than you should be driving a Hybrid or a solar car for that matter. There is no room for you here. Keep your opinions to your self, I didn't ask how to save the planet, I ask if you knew the belt size, which you don't. why did you even respond if you didn't know?
Jrpotts01,
I gave you my opinion as to the efficacy of disconnecting the smog pump. This is a forum for exchanging facts and opinions.
I did not get personal or angry. I did not say anything rude. If you do not want to hear calm, impersonal responses, then don't ask questions.
Furthermore, you are using a public forum to ask how to commit a crime. True it is a minor infraction. But you are using a public forum to ask how to do it.
I have not been rude to you. I expect, demand, the same in return. I have a science degree and have been doing engineering work for almost 30 years. I have rebuilt engines, transmissions, transfer cases, hubs, brakes, entire electrical systems, among other things on many types of cars. You may wish to ignore what I say, based on my knowledge and experience. However we all need to be respectful if this forum is to function fully.
-Lance
-Lance
Originally Posted by F151
Proven fact by the Mustang guys, you will net zero performance and milage gains for doing this...
Not trying to be smart, but all the comments and advertising I have seen on the subject is that it is worth 10-15 hp.
I would like to see some sources on the other side of the arguement, so to speak.
Edit:
Fwiw...
If you still have a cat in the exhaust, you are doing harm by removing the pump.
It keeps the cat functioning with catylist oxygen.
If the cat loses that, it will clog and bog.
Also, removing the pump requires plugging some plumbing around the engine.
Including the passages at the rear of the heads.
That said, if you do not have a cat in the exhaust... the pump is doing nothing whatsoever to stop asthsma or cure cancer or whatever wonders it does. Has to have a cat to mean squat.
Originally Posted by onefastermonte8
what about on a 96f250 351 88.2 would that be the same as a 302???
i'll get a new smog pump in time, but for now, mine siezed up and smells like its going to catch on fire.
Then route it around your pulleys as though the smog pump was not there.
Overlap it at the ends and measure how much is excess.
Subtract that amount from the stock length of the belt when layed flat.
Minus a bit more so your tension pulley can do it's job.
That will get you very close.
Edit:
When I say old belt off your truck, I mean one that was on there in the past. Not the current good belt.
I always keep old belts (that didn't self distruct) so I have a suitable backup in an emergency.
If you don't have an old belt, you can use a fabric type tape measure, or even a string to measure a belt if you route it like the belt goes.
bypassing smoggery siezup
i also have a 5.0 automatic with a siezed smog pump. I was looking into trying to prove haynes and chiltons wrong and rebuilding the internals of the smog pump. meanwhile i would have to bypass it or replace it. it is 70 bucks, almost, for a new one. but as near as i can tell from googling parts all over the net..., it is just a couple of plastic air impellers inside...
