diesel info / opinions please
91-95ish f-250 diesels : motor/tranny opts
Hi,
I've been toying with the idea of buying an older ( approx 91-95) f-250 diesel. I'm fairly familiar with the f-150's of this vintage and if I got a gasser, I'm partial to the 300 6's. I'm trying to weigh out the advantages of diesel vs. gas, but really know nothing about the consequences of the (at least) 3 different diesel engines (7.3 non turbo, 7.3 turbo, and 7.3 Powerstroke). Also, I would normally prefer a stick (in a gasser), but don't know about stick vs. auto in a diesel (primarily concerned with MPG and I will do limited towing). If it matters, I live in MN, so will see both extremes of temps.
Would appreciate feedback on these engine/tranny combos and/or general tips on looking at older diesels.
Thanks.
Hi,
Thanks.
on
The "Powerstroke" name was applied to turbo & non-turbo diesels, of several displacements. Your real choices are direct-injection (DI) & indirect (IDI), each turbo or non-turbo. I don't know enough about oil-burners to give you any advice on which is better.
The E4OD is much stronger than any stick offered in the 90s, and will give better mileage than most (with the possible exception of the ZF).
Diesel has been historically cheaper per mile than gas (the reason big trucks use it), but it's getting closer now. Biodiesel will probably re-open the gap.
But if you're not towing or hauling every day, and you want mileage, get a Focus.
'84-'87: 6.9L IDI
'87-'93: 7.3L IDI
'92-'93: 7.3L Turbo IDI
'94-'97: 7.3L DI (Powerstroke)
'89-'97 E4OD auto
'88-'96 ZF S5-42 five speed
'96-'97 ZF S5-47 five speed
Purdy much all are tough and no major trouble spots with anything. Two good sites to check out and research at are www.oilburners.net and www.thedieselgarage.com
Adrianspeeder
'87-'93: 7.3L IDI
'89-'97 E4OD auto
Adrianspeeder
