code 0171 keeps popping up
Old 08-09-2007, 07:27 PM
Watsonr's Avatar
Keep getting code 0171, lean bank 1 and then 1 time code 1131,
lack of HO2S11 Switch, indicates lean. Runs rough until I clear the code and may run a week without the code then here it comes again. Any help?
Old 08-10-2007, 08:49 AM
projectSHO89's Avatar
You have either a vacuum leak or a bad O2 sensor (or both).
Identify your engine.
Old 08-12-2007, 09:58 AM
Watsonr's Avatar
Thanks for your help, I was leaning toward bad O2. Checked for a leak and didn't find one. It indicated only one side and not both, didn't make sense just one side. Thanks again
Randy
Old 08-12-2007, 10:03 AM
signmaster's Avatar
Swap them out, should set a code for the other bank if the O2 is the problem.
Quick Reply: code 0171 keeps popping up
