please help me with my gas tanks
i have a 1995 F150 reg cab 2wd 4.9l. my truck has the 2 gas tanks ( i think all they all did) and the gauge on the front tank does not work. that is the only prolem i have with the front tank. the rear tanks gauge however does work but it is draining into the front tank. i am assuming that a return valve is messed up or something. i am going away to college at the end of Aug and would like for my truck to be perfect before i leave.
thanks for any help yall can give.
Fuel Delivery Module.
The front one is FUBAR.
The level sender isn't working and the shuttle valve is leaking. Neither is available separately and the shuttle valve needs to be replaced. When you install the new FDM be very sure to test for a signal on the sender before you button everything back up. There could be a lose wire or a bad ground which the new unit wouldn't fix.
That was a very clear answer to my question.
Dave
