Transferring gas with the fuel pump(s)
I've been using the dual tanks of my '96 as a sort of 'tanker' for the MC's. I remove the valve core on the pressure test schrader and attach a long piece of hose. I made a FP relay jumper w/toggle switch which I put in place of the relay to turn the pump on and off. My Q is: Anyone see any possibility of damaging the fuel pump doing this that I'm overlooking?
In case you're wondering why I'm doing this it's because our regional grocery store chain gives fuel 'perks' with purchases. The rules are once you build-up a discount and redeem the perks they must be used in one vehicle up to 30 gallons max. So you want to get the full benefit by filling a vehicle that has at least that capacity. I pretty much ride the 60 mpg bike in fair weather;-)
Thanks Steve, yes I understand the importance of not losing suction on the pump. I believe they rely on the gasoline for bearing lubrication. I think what motivated me to post the question was that while I'm running the pumps with the electrical jumper they'll begin making some noise and change pitch even with full tanks. Possibly this is normal and something one wouldn't normally hear with the engine running (or the pumps might be going bad?). I suppose if I'm going to make a habit of taking gas out of this truck regularly I should remove the anti-siphoning tube on one of the filler necks so I can just siphon it out easier.
The amount of information on your site is mind boggling!
