95 F-150 Ext Cab What Coil Springs To Get
Old 06-25-2007, 11:11 PM
FORD MANIMAL's Avatar
95 F-150 EXT CAB SHORT BED 5.0 AUTO W/AC P235-70-15.(stock) My front end is sagging and my front tires are waring on the inside. It is time for them to be replaced. I have added weight to the truck in electronics and a tool box in the bed (about 150-200lbs). I would like all of you fine Ford people to give me your input on the products listed below as a replacement. If you have used any of these products Please reply! If you use a diffrent brand I would also like your input as well! If I go with a leveling spring, What else will be needed to obtain proper camber, caster alignment? I want to keep a smooth ride and even tire ware. THANKS.
Autozone/Duralast(fcs822v) 180.00 plus tax (pair)
Summit/moog (mog-820,822,824) 69.95 plus shipping (pair)
Autozone/Trailmaster leveling springs (cs50) 239.99 plus tax (pair)
Rough country/leveling springs (part #-?) 129.00 plus shipping (pair)
Quick Reply: 95 F-150 Ext Cab What Coil Springs To Get
