AC switching between defrost and vents??
Just went thru this problem on my 93 302. Under the hood near the passenger side firewall, on top of the blower motor, there is a white vacuum line attached to it. This controls the recirculation door which is only used when the A/C switch is in the A/C High position. I just touched mine and it literally crumbled in my hand. I replaced just the section that was pitted and it has worked great since.
Ditto -- Exact same thing with mine. The famous white vacuum line failure!
I replaced the white plastic from end to end.
-Lance
-Lance
I got some of the smallest hose they had at my auto parts store. I made a small cut in the black tubing to open it up. The corroded part was just a little past the end of the tubing, so i cut the line where it was good and took the other end off, then i just slid the new hose over the piece coming from the firewall. I then put the other end on the vacuum motor for the recirc door. I taped the cut i made in the black tubing and everything works.
