81 ford f-150 4.9L emissions
Old 06-15-2007, 12:16 PM
coloredred's Avatar
I replaced an 81 engine with a 82 4.9l and now I seem to have extra vacuum ports. Anyone with an 81 who can take a picture of the vacuum connections near thermos stat housing? Are there connections there? The picture on grill is faded.
Old 06-15-2007, 02:13 PM
Steve83's Avatar
If you can't find the appropriate vacuum diagram here, you can here.
Is it a vacuum port (small), or secondary air (BIG)?
Old 06-18-2007, 01:36 PM
coloredred's Avatar
vacuum diagrams
Whats VCV?. Is there a place I can look to see what these are, Vreser, VCK V? The part in question is on the thermos stat housing. It has 4 or 5 places to connect a vacuum hose and they are small.
Thanks Sam
Old 06-27-2007, 01:52 PM
Steve83's Avatar
VCV = Vacuum Control Valve
VCKV = Vacuum Check Valve
VRES = Vacuum Reservoir
TVV = Thermostatically-controlled Vacuum Valve
I think we made a thread about abbreviations & acronyms on FSB a year or 2 back, so try a few searches there for more info.
That's a 4-port TVV you're describing, and it's used to control the heat riser valve & the EGR.
Quick Reply: 81 ford f-150 4.9L emissions
