Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 06-06-2007, 10:40 AM
Garage is empty, add now
How to install serpantine belt in 94' f150?
Well, my belt blew off last night and i need to put a new one on, i cant seem to figure it out with the diagram.
Is there a step bt step for installing one? Any tips? What pully should i start on?
Thanks guys.
Old 06-06-2007, 01:29 PM
Vehicle: 1995 Ford F-150
Send a message via AIM to earnedit3
Serpentine belt
Hey Papadye, the diagram is pretty easy to follow, just take a deep breath, find out which pulley is your tensioner, the spring loaded one, and go clockwise following the diagram. I had to do mine twice before I found out I went the wrong way around one of the pulleys. DEEP BREATH, go slow. Good luck.
Old 06-06-2007, 02:42 PM
Vehicle: 1954 F100
Send a message via Yahoo to easterwabbit
we are right now putting a new tensioner and belt on the company truck its a 95 F250
if you have no luck yet i could let you know how we did it
good luck
Randy in Lincoln, IL 5/8/07
1997 F150 pickup 4x4 4.6L 4r70w POS; 1954 F150 pickup mostly restored; 1957 ford pickup; 1977 F150 pickup mostly restored for sale 6500; always parting out: '69 fairlane, '54 ford truck, and others!
Old 06-06-2007, 05:20 PM
Vehicle: 2001 Ford F-150
If it's the 300, the tensioner is near the "top" driver side of the motor. Easily accessible. If it's a V8, it's farther down and significantly more of a p.i.t.a to release. If possible, get an assistant to hold the tensioner back(though if either of you is of ahem...extended size this could prove difficult. Otherwise it really is just following the diagram, not a whole lot of advice to give.
Old 06-06-2007, 09:50 PM
I got it on this mourning, it was super easy.
but......it wont tension up, i think the tensioner broke when the belt flew off, is there surpossed to be a black plastic part on the tensioner? Or does it ride on the metal part?
I can take a picture if you dont know what iam talking about...
Thanks guys!
Old 06-06-2007, 11:28 PM
1983 Ford Bronco
Vehicle: 1983 Ford Bronco
Click the image to open in full size.
You can buy aftermarket replacement idler/tensioner pullies with bearings for ~$10ea. Much cheaper than buying the whole OE tensioner, and you get a LLT warranty.
Walk softly & carry a BIG SIX ! ! !
Old 06-07-2007, 10:20 AM
Looks like i need a new tensioner pully.
Are the idler and tensioner pulleys the same diameter?
Old 06-07-2007, 01:02 PM
1983 Ford Bronco
IDK. Ask the store where you buy it if they're the same.
Old 06-12-2007, 02:09 PM
Vehicle: 1954 F100
1995 5.0L
tensioner one is metal
idler one is plastic
just replaced the whole tensioner assembly a bit ago on it, napa has them for 36 bucks, gates brand in white box
dirt cheap
Old 06-12-2007, 04:15 PM
Vehicle: 1995 ford F150
Tip
put a breaker bar on the tension pulley to hold it and use safety wire to hold it while you are threading the belt on to the pulleys
Bruce
Old 06-13-2007, 04:48 PM
Vehicle: 1954 F100
yep and its really easy on these, just need a long ratchet or bar and a socket, these tensioners dont have a ton of resistance, as per say on front wheel drive cars and such,
simple
also if the belt flew off then you may want to replace the tensioner because the info that comes with the new tensioner states that you cannot cut the belt off because of the shock of the tensioner unloading when the belt comes off suddenly will damage it
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
