05-28-2007, 06:01 PM
New truck today! No seatbelts, though
Hey gang! Today I picked up my very first pickup. It's a white on red '95 2wd 5.0 5spd XL. Our first day together was fun, but the receivers for the seatbelts were in the glove box instead of bolted anywhere.
I don't have a service manual or even an owner's manual for the truck yet, so I really have no frame of reference as to where these are supposed to go.
Where do the seat belt receivers attach? To the floor? To the seat?
Anybody have any pictures or tips for me?
Thanks a lot!
05-28-2007, 08:08 PM
If it's a bench seat, they bolt to the floor and the actual clip is just stuffed between the "halves" of the bench seat. The driver side clip is by itself, the middle and passenger side clip are both on one anchor piece, which bolts pretty much "between" the passenger and middle of the bench.
For a split seat or the two captain's chairs, they bolt to the floor next to each seat.
05-28-2007, 08:56 PM
Yeah sorry, bench seat. OK I must be missing those mounting pieces. I'll have a look. Thanks!
05-29-2007, 01:44 AM
1983 Ford Bronco
Vehicle: 1983 Ford Bronco
The same 2 mounting points are used for all the belts, regardless of what type of chair is used. They're in the floor ~1/3 of the way across from each side. A shouldered T50 bolt goes in each one, and it's easy to get those bolts from Fords in the junkyard.
05-29-2007, 05:23 PM
Ya, the actual strap is looped and sewn through a metal shackle that bolts to the floor. I suppose you could just run a screw through the belt, but I imagine that would compromise it's integrity and may not pass inspection.
05-29-2007, 05:28 PM
Ok we'll use eBay as a reference: http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
Note: Not my auction, not used with permission, blah blah blah... Ok check out the receivers in the first picture there (the items on the very top and bottom). That is just what I have. I don't have any bracket under the seat or anything else to attach those to, and they are too short to reach directly from the floor to the holes in the bench seat.
Could anyone snap a quick picture of the bracket mount underneath the bench there?
05-30-2007, 02:35 AM
1983 Ford Bronco
There's no "bracket" - just a bolt that goes thru the hole in the mounting tab into a hole in the floor. If they're too short, they're not the right parts for your truck.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
