Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 02-27-2007, 05:42 AM
Garage is empty, add now
Vehicle: 1995 Ford F150
Shaking at higher speeds
I drove up to the mountains a few weeks ago and sheared my automatic hubs trying to rock myself out of a snow back that I got stuck in. Ever since then my truck has been shaking at speeds between 35 and 70mph. It's not teeth chattering like the washboard effect some people get; it feels more like slight imperfections in the road. Feels sort of like an out of balance tire, but I have had the truck in twice to get the tires balanced in the past weeks. The vibration seems to be coming from the drivetrain as I feel it more under my *** than in the steering wheel. I have since replaced the hubs with Warn premium manuals, replaced the fluid in both differentials, and checked the u-joints by twisting the driveshaft around them looking for play -- none. Any ideas?
-Chris
Old 02-28-2007, 07:26 AM
Any help here guys?
Old 02-28-2007, 11:34 PM
Vehicle: 1997 Ford F50 HD
Try Sea Foam tranny treatment first, cause it is the cheap fix.
Then try replacing the filter.
Then if that does not work, have a mechanic check for torq chatter.
-Vycan
Old 03-01-2007, 04:39 AM
Thanks for the reply.
As for the tranny fix fluid, I already have Dr Tranny Shudder Fixx running through the tranny right now from when I was trying to fix a different shudder I had before, due to a carrier bearing needing to be shimmed (fixed it). In light of this I don't want to add anymore friction modifiers or quick fixes, nor do I think that they would help since the first one isn't doing much in there.
As for the filter: I just changed the filter and fluid to Amsoil synthetic about 1-2 months ago, so that wouldn't be the source of my problem.
I guess I'll have to take it in to be looked at... Somehow I don't think its transmission related because the shake seems to continue after I put the tranny in neutral and coast down a hill. Thanks for the tip. Still looking for suggestions.
-Chris
http://www.f150online.com/galleries/....cfm?num=12073
1995 F150 w/ Centurion Crew Cab Conversion
5.8L 351 V8 & Auto Trans
4WD w/ 4" Pro Comp Lift
Old 03-09-2007, 11:37 AM
csonka
Guest
Posts: n/a
I am having a similar issue. You can watch my thread if you'd like here:
http://www.f150online.net/forums/sho...d.php?t=276763
Btw where are you getting into snow at?
I use to live in Marin, boy do it miss it!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
