Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 02-14-2007, 03:23 PM
Garage is empty, add now
Vehicle: 1995 ford f150
Turbo F150 project.
A while back when I joined up i posted that I was starting a turbo project on my 95 f150. Well I finally finished it last night, minus tunning. here are a couple of pics.
I will try and post better ones when I get a chance.
All pipes layed out
Wrapped Up and Down pipe
intermediate work on piping.
some more in work pics
I have a bunch of pics on my MYspace page. www.myspace.com/tanterror
and a video as well of the very first start up of it.
Can't wait to start tunning it.
later,
Scott
Click the image to open in full size.
Old 02-14-2007, 05:00 PM
Vehicle: 1995 Ford F150
Send a message via AIM to plumprowler Send a message via MSN to plumprowler
Good stuff. Which engine is that? I have a friend interested in turbo-ing his 351.
Old 02-14-2007, 05:42 PM
its the 351 as well, it made some really unimpressive power when it was stock. Now I have swapped a gt-40 intake, and added a 57mm turbo. Not big, but should liven it up a little.
Old 02-14-2007, 08:29 PM
Vehicle: 1997 Ford Blown Expy
Sweet.
How many psi?
How are you adding fuel to the mix?
Old 02-15-2007, 03:30 AM
I only plan on running about 6-7 psi. Nothing major. for fuel I am running 36# injectors, 255lph pump, and tunning it with a tweecer and wideband. an intercooler is in the works as well. This is usually my daily driver so I am trying to make it fairly reliable. Will be running a conservative tune, not trying to build a drag truck
Old 02-15-2007, 03:21 PM
Nice.
Stock heads?
Old 02-15-2007, 10:10 PM
yeah the only thing not stock on the engine is the intake. One of these days I will go through the engine but that is sometime down the road. I have too many projects so this one is supposed to be simple not too involved. (Right)
Old 02-15-2007, 10:22 PM
Vehicle: 1997 ford f150
what are the specs on that turbo?
Old 02-15-2007, 10:32 PM
the hot housing is a .96 and the compressor housing is a .60 this is my first turbo project so not a super guru on them yet. don't remember the trim.
Old 02-15-2007, 10:43 PM
**edit** double post
Old 02-16-2007, 07:19 AM
Thanks! let us know how the response is! the trim i believe is the major diameter of the comp wheel divided by the minor diameter
Man,I wish i had a v10 f-150
http://www.f150online.com/galleries/....cfm?gnum=7988
Old 02-17-2007, 02:28 AM
That's freakin awesome. Watch your wrapped pipes, sometimes the wrapping collects moisture and will rust those pipes out. A few guys on FEOA.net did that with their Scorts and they say don't mess with it unless it's a strict drag car. I realize now you're from Arizona, so it probably won't happen as easily.
Old 02-17-2007, 03:01 AM
yeah we don't get a lot of moisture out here My big concern is not frying everything in the engine compartment. I can make a new pipe easier than some of the other crap that may turn into a pool of melted plastic. I have heard of that I know it is a concern but with a couple inches of rain a year, I will take my chances I guess. I really don't know what else to do without moveing all my harnesses and crap. As you can see I also wraped the heat barrier around everything. block 90% of head up to 2K* not bad. and it really does work too. I stuck my had under that mat after driving and it was still cool.
Old 02-17-2007, 04:46 AM
Man that is some good stuff. Good luck with the tuning man.
Old 03-19-2007, 04:39 PM
thought I would add a quick update. Over the weekedn I installed an Intercooler. Much better now. I also replace the waterpump with a High flow and a 180* TS. The truck was running too hot for my likeing. I think the WP was about to go out anyway, started leaking. I have about 130K on the truck. So now with the Intercooler, I went ahead and bumped the boost on up to about 8psi. Much better. Wtih 3psi I raced a mostly stock 03 lightning and lost by about 3 lengths. So now with 8psi, I think I should take him. Well see sometime this week. I still have my timing in the mud right now too. I pulled lots and lots of timing out of the tables and added a lot of fuel at the moment. So there is still lots of potential left.
thats all for now.
later,
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
