12-12-2006, 12:21 PM
Oil for 95 F150 with 300 I-6
I was wondering what would be the best oil to use for a 95 F150 with a 300 I-6. I have about 155K on it, and since about 50K it has had only Mobil 1 10w-30 synthetic. I heard that it may be better to use Rotella T HD synthetic, but I wanted to see what everyone's opionion was on this.
12-12-2006, 01:30 PM
Garage is empty, add now
Vehicle: 11 FULLsize ole' Ford rigs
Keep using what works.
Adrianspeeder
12-12-2006, 03:29 PM
1983 Ford Bronco
Vehicle: 1983 Ford Bronco
If you begin to notice any rattling or other symptoms of low pressure (esp. in the summer), you could go to a SLIGHTLY heavier oil during the hot months & back to the thin stuff in winter.
Mine was a junkyard engine, and I don't know how it was treated before I got it, so I use 20W50 in summer & 10W40 in winter.
Also, there is some question now about M1 being a TRUE synthetic any more. Mobil came down hard on Castrol when it started marketing highly refined dino oil as "100% Synthetic", but now many people think Mobil is doing the exact same thing.
12-16-2006, 08:59 AM
Vehicle: 1995 Ford F150
I use Mobil 1 10w-30 in mine with no complaints.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
12-16-2006, 11:51 PM
Vehicle: 1992 Ford F-150
We have a 95 with the I6 engine that has always had Mobil One 10w30 changed every 7,000 miles (hwy), has 220K on it now with no problems whatsoever. Unless you are experiancing problems like low oil pressure or excessive oil consumption keep using the 10w30. The thicker stuff is harder to pump through the engine during a cold start.
-Jon
Also In The Fleet:
2005 F-250 Superduty 4x4
1996 Dodge Dakota Sport with Ford 393 stroker
12-18-2006, 07:25 PM
Just read this today - Oil formulated for diesel engines, like Rotella T contains more zinc and phosphates that oil for gasoline engines. Those two chemicals help better protect the engine against friction and wear...But it is bad for your catalytic convertor and oxygen sensors so its best not to use it in modern EFI gas engines.
-Jon
12-19-2006, 09:54 PM
Redline 10w30 here.
Vince
12-23-2006, 08:06 PM
I have had several 300's in my life, the last one was a 94, I always used 20/50 in the summer/spring/fall and 10/40 in the winter
all of the past generation pushrod v8's I would recommend the same
depending on where you live and how cold fall and spring are, you may chose to put 10/40 in it then
12-23-2006, 11:47 PM
Quote:
At how many miles did you start using Mobil 1?
12-28-2006, 06:41 AM
Quote:
I started using Mobil 1 at around 30k miles, +/- 5k.
Webmaster:
Rice Haters Club
My F-150 Gallery
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
