Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 12-10-2006, 05:11 PM
Garage is empty, add now
Vehicle: 1992 Ford F150
Catalytic Converter Heat Shield
Hey all,
There was a clanging coming out from the bottom of my 92 F-150 Custom and I peaked underneath to see that half the heat shield (if that's what the metal plates are that are bolted to the outside of the second catalytic converter) was extremely loose. The corners broke free of their bolts and only one corner was left on, so I just pulled it off. If that is a heat shield, and it's not on the converter (side of the converter facing the tranny), will it produce enough heat to do damage to the transmission (the transmission is automatic and the transmission case is right next to the cat converter) and if not, is it something that's terribly important to replace and how expensive is it. I'm a college student without a whole lot of money, I'll get around to replacing it, but if it's not too important I've got other things like rent and stuff that are more important to take care of right now. Thanks.
Old 12-10-2006, 05:14 PM
Vehicle: 11 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Heat is the enemy of the E4OD. Should be pretty simple to have it rebolted/welded back on.
Adrianspeeder
Vehicle: two 2003 F-150s
Send a message via AIM to Patman
you probably can take it to a muffler shop, and just have them reclamp the heat sheild, and maybe tack weld (spot weld) it in place on a few spots on the sheild.
I personally wouldnt risk running it for extended periods where heat builds up more.
Edit: Grrr adrian beating me to first post, by a matter of seconds...
-Patrick
Old 12-10-2006, 07:03 PM
Thanks guys.
Old 12-11-2006, 06:48 PM
So I took it into Midas today to see if they could weld it back on. They took it back to look at it, came back out and said they welded it back on, handed me my keys back, and said Merry Christmas. They welded it back on for free.
Old 12-11-2006, 08:45 PM
Thats great man, make sure to support that shop in the future.
Adrianspeeder
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
