Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 10-15-2006, 02:00 PM
Garage is empty, add now
Vehicle: 1993 Ford F150
Speedometer/Cruise Problem
Lately my speedometer has been goin a little wacky. It has always been 5 mph slow but recently its starting to go on the fritz. If I drive constantly at say 65, it will drop down to 50ish every once in a while and jump back up. There has always been a little wobble in it but now its gettin ridiculous. Also since it has starting doing that, when I set the cruise, my truck constantly lurches. I figured it had something to do with that. Could it be a broken tooth on my speedo drive? If so where is it located. Also I bent the exciter ring on the rear diff if that makes a difference but i thought thats only for rear abs.
93 Flareside. 351W. True Duals. 33x12.50's.u/d pullies
Old 10-15-2006, 03:52 PM
1996 Ford F-150
Vehicle: 1996 Ford F150
The exciter ring IS your speedo drive. The ABS sensor doubles as the vehicle speed sensor. If the ring is FUBAR, the speedo and cruise control will not work properly. If you have an auto tranny, it will likely act weirdly as well.
Old 10-15-2006, 04:34 PM
Vehicle: 11 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
'92-96 use the VSS on the rear diff for the odometer, speedo, cruise control, ABS, and the shifting of the E4OD/4R70w.
Adrianspeeder
Old 10-15-2006, 09:36 PM
Oh, well in that case, where can I get a new one? I noticed they don't have them on the broncograveyard.com
Old 10-15-2006, 11:02 PM
1996 Ford F-150
They're about $35 from Ford
Old 10-16-2006, 08:21 AM
29 when I bought mine from ford about 3 years ago.
Adrianspeeder
Old 10-16-2006, 10:54 PM
well its gonna suck pulling the 3rd member again and the ring gear. O well guess i shouldn't have pryed on it. Oh, how does it come off, there aren't bolts or anything
Old 10-16-2006, 11:07 PM
1996 Ford F-150
Getting the old one off is not an issue if you're going to pitch it anyway. Mine succumbed to a hammer and screwdriver.
The replacement goes on very easily if you heat it up to 350-400°F in the oven and drop it in place while still hot.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
