1992 f150 towing capacity - please help
i'm getting a run around from the local dealers and the best ford could do is to promise me that they'll mail me a towing guide which contains a formula to figure out a towing capacity...
anyway, it's a 1992 f150, straight 6, 5 speed manual. can someone help? and i'm not looking for capacity on the bumper hitch but on a regular hitch (whatever you call them, a class 2).
thanks in advance!
mnk
thanks in advance!
mnk
thanks everyone!
i'm told that it's actually 4750 lbs, so i'm not sure where the other poster got the 2000lbs from. regardless i'm shocked.
i need to tow a horse trailer w/ at least one horse in it. glad i looked into this before i comitted myself to a steel trailer that weighs 3000 lbs empty.
Originally Posted by mnk
thanks everyone!
I can guarantee you that is wrong. The actual numbers depend on which rear gears you have, but the absolute most you could hope for, according to Ford, is 3600 lbs. fully loaded. The maximum loaded trailer weights are as follows:
For a '92 Regular Cab 300ci / 5 speed w/ a rear gear ratio of:
2.73: 2100 lbs.
3.08: 2300 lbs.
3.31: 2900 lbs.
3.55: 3600 lbs.
For a '92 Super Cab 300ci / 5 speed w/ a rear gear ratio of:
3.08: 2000 lbs.
3.31: 2700 lbs.
3.55: 3400 lbs.
Again, those weights include the weight of the trailer itself, as well as the load.
If your trailer weighed 3000 lbs. empty, the most you would be able to add is 600 lbs., and even then only if you have 3.55 rear gears and your truck has a regular cab. This according to Ford.
