oil pan leaking
You could drain it and TIG up the hole if it's far enough from anything vital, but I suspect it's a losing battle. There's other weak spots just waiting to bite you. If it were mine, I'd probably end up pulling it and replacing it with something nice from Canton
While you've got the pan off, inspect and clean the pump strainer. Replace if required.
