Is there a bleeder valve for power steering?
Old 07-31-2005, 04:56 AM
ajrn's Avatar
Hi..
86 f150 4x4-- 300 six...
It cut the power steering belt a few weeks ago.. Somehow in the process it warped (BADLY) the drive pulley. The pulley had fused on pretty good, and a junkyard pump was $35 complete, so I decided to quit messing with it and just 'swap' the pumps..
Once I got them swapped-- I went to look for a bleeder valve (since it's a hydraulic system, I expected to find one).. Alas, I don't see ANYTHING that resembles one..
Does the air (if any entered) get worked out over time-- or am I missing a bleeder somewhere..
It's summer, so the truck sits more than it moves.. I ride my motorcycle as much as possible.. Just don't want to do more harm than good.. The truck has been good to me, for the $500 I paid for her.
AJ RN
Old 07-31-2005, 07:17 AM
subford's Avatar
Bleeder valve.NONE
Does the air (if any entered) get worked out over time-- YES
Keep an eye on it, and add PS fluid as needed untill all of the air gets
out.
Old 07-31-2005, 07:58 AM
RockyJSquirrel's Avatar
Does it squeel? Noise will indicate air in the system. With the engine running, turn the steering wheel back and forth from one stop to the other a couple times. DO NOT hold the wheel hard against the stop. Recheck your fluid. Bleeding is complete.
Old 08-03-2005, 06:37 AM
ajrn's Avatar
Thanks-- That was what I was hoping..
I'm going to start a separate thread.. I can't seem to get the pump to line up 'correctly' and it keeps flipping the belt upside down..
Ugh.. Looking for this saga's end...
Quick Reply: Is there a bleeder valve for power steering?
