what x-fer case do i have
Old 06-20-2005, 03:22 PM
David Despain's Avatar
95 f-150 auto tranny 5.0L eng. extend cab manual shift transfer case lever. the transfer case has a crack in it at the drain plug and i need to know what kind of case it is and where to get a replacement or a rebuild kit or something
Old 06-21-2005, 08:24 AM
adrianspeeder's Avatar
The broncos had Borg Warner 1356's, I assume the F150s are the same. Do you know a good welder? Or can you go to a junkyard and pull one to swap?
Adrianspeeder
Old 06-21-2005, 11:28 AM
i dont know if it can be welded the crack is along the length of the drain port perpindicular to the threads so i dont know if it would be worth trying to weld the entire crack closed from the bottom of the case to the threads then i would have to cut new threads etc. i think i'm going to try to find a used one some where and overhaul it that way the truck isnt down for too long.
can anyone tell me the difference between the borg warner 1345 and 1356? can they both be electric shift?
Old 06-21-2005, 01:04 PM
after some more looking i am convinced i do indeed have a bg 1356. i dont think i will try to get it welded since its magnesium and i have a feeling to have someone weld that it would be cost prohibitive. there is lots of info out there here is some decent info http://www.fourwheeler.com/projectbuild/129_0406_red/
thanks for your help
Old 06-21-2005, 03:22 PM
I am not familiar with the 1345, but the 1356 can be electronic shift on the fly or manual shift on the fly. I would stick with the manual.
Adrianspeeder
Quick Reply: what x-fer case do i have
