Will this tranny swap work or not? Please help
The tranny will "fit" but it may not be all that easy. What exactly are you trying to do?
Does the 93 currently have an automatic or a manual? If an automatic, which one? If you have an electronically controlled automatic, you're going to need a PCM and powertrain wiring harness from a 93 manual tranny truck.
Does the 86 have a mechanical or a hydraulic clutch? If it's mechanical, you're going to have to convert it to hydraulic.
First of all toploaders don't have granny gears and 86 F150s didn't have toploaders. If it looks like a toploader, it's really a SMOD tranny which doesn't have a granny either. You'd need a T-18, T-19 or NP-435 to get the granny.
Take a look here http://www.motivegear.com/tech_info/...nny_guide.html
If you're really looking for a tow vehicle, you're time and money ahead keeping the AOD and upgrading it as required
