clutch adjustment
It bleeds like a brake system. There is a bleeder valve on the slave cylinder just above the hydraulic coupling at the trans. Open it and let it gravity bleed for a while, then pump the pedal for a couple of minutes to let the air out of the new master cylinder. The pedal should get firmer the more pumps. Then you could try pumping and holding the pedal and open the bleeder just like brakes. Good luck,
Robbie
Robbie
