96 f150 5.0 dies wont restart
Old 04-08-2005, 09:36 AM
hotwheels645's Avatar
Angry 96 f150 5.0 dies wont restart
I HAVE A 96 F150 WITH A 5.O AUTOMATIC DUAL FUEL TANKS. I REPLACED THE ENGINE WITH A REMAN LONG BLOCK LAST OCT.(THATS ANOTHER STORY) THE ENGINE RAN GREAT I DROVE IT OVER 300 MILES R/T EVERYWEEKEND FOR THE NEXT TWO MONTHS. I MOVED AND WAS ON MY WAY TO WORK ONE DAY AND IT JUST SPUTTERED AND DIED AND WOULD NOT RESTART. I LEFT IT AND WENT BACK TO IT AFTER WORK IT STARTED RIGHT UP. IT RAN FINE FOR 2 MORE WEEKS THEN DID IT AGAIN. I MADE A 160 MILE R/T THE FOLLOWING WEEK WITH NO PROBLEMS. THE NEXT DAY I WENT 3 MILES UP THE ROAD IT DIED AND WOULD NOT RESTART FOR ABOUT 20 MIN. I REPLACED THE COIL THAT DID NOT HELP. I HAVE A 1993 F150 COMPUTER IM GOING TO TRY AND SEE IF THE #S MATCH MINE .. I DOUBT IT WILL WORK. ANY SUGGESTIONS? I REPLACED ALL WIRED PLUGS ROTOR CAP COIL WHEN ENGINE WAS REPLACED. I DO KNOW MY OXYGEN SENSORS ARE BAD.
Old 04-08-2005, 05:10 PM
JimR1's Avatar
Are you getting spark after it dies? Maybe the spark control modual in the distributor going bad? Just a guess.
Old 04-18-2005, 03:19 PM
OutCast's Avatar
Could be fuel related. Hook up a pressure gauge and see what's going on.
Old 05-18-2006, 06:25 AM
EvilF150_2's Avatar
Mine does the same thing. I get a code 542 (Open in secondary fuel circuit) from the code reader after it has died. When it hasn't died, both KOEO & KOER codes are 111(All is well). Fuel pressure is great! Problem is very intermittent. When I run the multimeter on the components, all checks out. I was getting some odd readings on the fuel pump connector, but it was getting dark and it could have just been me. I will update once I find the problem. Oh yea, it's a 95 f150 with a 5.0(302), single tank, 5spd.
Old 05-18-2006, 09:21 AM
inline6dude's Avatar
you can do the ecm and see if that helps, i had the same problem except mine would sputter die and then fire up and die shortly after..i had my shop pull the whole distributor and they said that a magnetic ball that goes to the cam was bad and causing this, idk exactly what it is called but they had to rebuild it...but i did the ecm first and it helped..just an idea...i know what your talking about and it really Pisses you off..good luck...post back
Old 05-18-2006, 07:46 PM
PKRWUD's Avatar
Your ICM (formally known as TFI module) should be mounted to the drivers side fender, just below the hinge. Use a hair dryer, set to low, and with the engine at idle, turn on the hair dryer and aim it at the ICM. If the engine hasn't stalled after 5 minutes, the ICM isn't the problem. If it does stall, replace the module.
Quick Reply: 96 f150 5.0 dies wont restart
