Water Pump bolts wont go back in
Old 03-07-2005, 04:15 PM
aclsarescary's Avatar
Angry Water Pump bolts wont go back in
On sunday I replaced my water pump. I went to put on the other water pump and two of the bolts will go back in, but the other two will not.
I dont know what to do. Could the bolts be stripped or be a cause of corosion on the threads?
If anyone has any insight it would great.
Old 03-08-2005, 09:34 AM
zapster's Avatar
are you sure your putting the SAME bolts in the SAME holes they came out of?...common problem..some are just that much longer and if you put a long bolt in a short hole then bad things can happen..like on a 6 banger you can actually put a hole in the front cylinder if the wrong bolts are installed in the wrong place...zap!
Quick Reply: Water Pump bolts wont go back in
