91 f150 door panel removal???
Old 02-27-2005, 05:54 PM
74duster318's Avatar
My passenger side window quit working today in all the snow and stuff. I need to know how to remove the passenger side door panel so i can see what's wrong with the window. My truck is a 1991 f150 reg cab.
Old 02-27-2005, 06:57 PM
Fordman8694's Avatar
Is your truck equipped with power windows and locks? or manual?
If it is manual, you'll want to remove the window crank, and unscrew the door lock cap (if you have to in order to lift the panel off) and all external screws (if any) that hold the panel in, then slowly and carefully pop the door panel off. The clips can be replaced if they break.
If it's power, its the same thing, just without the window crank of course. Just remember to unclip the harnesses for the power windows/locks when you pull it off.
Old 02-28-2005, 08:53 PM
Thanks alot man, i got them off today, and none of the clips broke. I got to looking at the window and the gear wouldn't engage the motor at all unless i was pushing or pulling up or down on the window. So i just pulled the window up and left it untill i get around to overhaul the truck this summer. Thanks again for the help, I really appreciate it.
Quick Reply: 91 f150 door panel removal???
