Best way to boost power??
I'd lop off the cats in favor of a highflow one. Then run a 3" pipe from there back to your choice of muffler... I prefer Dynomax or Magnaflow.
Drop in K&N with hacked box works nice or you can get the Speed Density EFI K&N FIPK filter and two lengths of 3" piping and stick it on the end of the hose connections.
180° thermostat, and bump ignition timing to 13-15° BTDC. That's if you run 91+ fuel.
That's where I started... 5.0 Mustang shorty headers bolt up to a 302 but you can NOT use the stock y-pipe so you must fab a new one.
A mild TQ/RV cam or a 5.0 HO will make a big difference. E-fans, chip burned for the mods and to bring full timing in sooner, new heads, etc.
All depends on budget...
