Whackyass Problem on a 1982
Right, I have an '82 F-150 XLT with a 300 I-6, 2WD, Long Wheelbase, Single cab, 4 Speed Auto, with A/C, Power steering, power brakes. The problem is one that stumps anyone that looks at it, because, seemingly at random, It won't start. You turn the key to run, the "charge" and "oil" warning lights go on, the heater and A/C work, everything's normal. Then you turn the key to "start", and nothing happens. The warning lights dim, all the electronics turn off, like they are supposed to, and the engine does nothing. Sometimes, after you turn the key back to "run", or "lock", the whole truck shudders pretty good, but like everything else, that's occasionally at random. For the most part, it only did this after you had to crank the starter for too long (10-15 seconds), but I replaced the starter, now it does it less often, but I can't even tell when it will. Sometimes it's cold, hot whatever. It just doesn't even crank the engine. I've replaced the
voltage regulator,
starter,
alternator,
battery cables,
fuses,
fusible links,
ignition,
cap and rotor,
spark plug wires,
spark plugs,
All the wires I can get to,
(I used all Motorcraft parts, if that means anything. Cost me a pretty penny)
I've taken apart the steering collum, and found nothing wrong with anything in there. This has honestly got me stumped. I've let a few local mechanics look at it, and they have no clue. The truck has 124,380 miles on it, and has never been wrecked. Any ideas?
Oh, and if I forgot any information that may be helpful, lemme know, and I'll post it up.
voltage regulator,
starter,
alternator,
battery cables,
fuses,
fusible links,
ignition,
cap and rotor,
spark plug wires,
spark plugs,
Check the ignition switch on the bottom of the steering column. Its a black plastic switch with a rod going to the key switch. when you turn the key the rod moves the center part. I had a problem with my 82 bronco. it was this switch what was cracked and not working correct. Oh ford changed this switch in 82 but my 82 still had the 81 style.
ignition switch
had similar prob. called mechanics nothing they didnt no. turned out to be a ignition switch mounted at bottom of steering column top side. it was weird i had just put a new 1 on so never thought it was a problem but it was part looked fine but looks can be decieving there cheap try it. buy it at local parts store no need for motorcraft
