E4OD Floor Shifter?
actually, i have done it. it is easy. you first cut a hole in the floor where you want your shifter. then run a cable from the shifter to above floor level. then hook a lever that you can buy from autozone on to the cable. then find a fitting that will go around the lever so it looks like it came stock. then you have to hide your existing shifter.
