High idle and dieseling
My ’86 with a 4.9L engine is idling too fast (don’t know the rpm) and diesels when I shut it off. I read and made the adjustments called for on the sticker but actually everything was correctly adjusted. I think my ECT (engine coolant temp) sensor, which you need to disconnect when you make that adjustments, is defective and giving the controller a bad signal…. but what do I know. How would one check that sensor out? Or is there another obvious problem that I haven’t thought of?
Thanking you in advance for what I know will be good advice.
Bob
Bob
