Cluster change Question.
Old 08-12-2004, 06:05 PM
ajrn's Avatar
I'm changing out the stock cluster with one I found, that has a tach, and trip odometer..
How do I get the light switch, and wiper switch ***** off, to get the old cluster out..
AJ RN
Toledo's ORIGINAL Chromehead
Old 08-13-2004, 02:36 AM
ajrn's Avatar
Hmm..
Okay.. Let me rephrase...
Do I need to remove them or can I wiggle the cluster out around the bezel??
AJ RN
Old 08-13-2004, 08:46 AM
ccnseven's Avatar
I have a 92', if you'rs is like mine you will have to remove them. The light switch is one I fought with but you have to use a small tool with a 90deg bend on it and press into the hole or slot behind the light switch and depress when pulling off. There is a post on this web site with pictures on how to do it exactly, you will have to search for it, its been within the last year. The shift indicator will have to be lossened and pushed aside as well then it will come out.
Old 08-14-2004, 01:31 PM
ajrn's Avatar
Shift Indicator??
OHHHHHHH! I have a manual transmission...
Whew..
Thanks for the hints..
AJ RN
Quick Reply: Cluster change Question.
