'95 F150 Power Steering Leak.. Help!
Most likely the seal behind the pulley on the shaft. Hard to see and it can be even harder to get at. You can either replace the pump or replace the seal. But either way you will probably need the puller for the pulley. I think I paid $25+- for mine at Advance and they are worth EVERY penny. Some of them have to have the pulley remove to get it off of the mount.
Before removing the pump be sure to check everywhere else tho, could be a bad hose or connection too.
