Can Start Truck W/O Key!
My dad goes to pull the key out of his 94 F150 XL 4.9 and it does not want to come out. He proceeds to push it in and out a few times, and then it finally comes out. Just for the heck of it, he decides to just turn the ignition forward, w/o the key in it, just to see if it would start, and guess what, it did! So now he doesn't need the key start the truck at all. What has went wrong and what needs replaced to make the truck normal again? Thanks!
You need to replace the lock cylinder. The tumblers are worn out. My wifes Taurus is the same way. But if you pull the key and wiggle it it will lock. I don't let it bother me, it's actually rather convienient sometimes.
You can pick them up at Advance or ? or ? whatever chain is near you for about 15 bucks. Pretty easy to change. It's best to replace them before they go completely cause then they are a real b!tch.
