Air Charge Sensor
yes it is. Clean it with carb. cleaner and put it back in. Your whole intake system is likely full of that black crud caused by oil vapours condensing there and no fuel going by to clean it off (as in the old carb. or throttle body injection days). The main problems are the throttle body getting gummed up, the IAC getting gummed up, and your sensor getting gummed up. Other than that the only other problem is slightly reduced air flow in a badly gummed up system.
