Low Oil Pressure...
Low Oil Pressure...
My Oil Pressure gauge normally gives a reading between the "R" and the "M" on the NORMAL indicator. However, for the past couple of days, it has gone down between the "N" and the "O" and even sometimes right on the "N". Although this is still technically in the "normal range", I am a bit concerned as to the cause of this. I checked the oil level and it was a bit low so I topped it off and drove about 50 miles or so and it is still reading on the "N". What are some other causes of low oil pressure that I should check into? Any help would, as usual, be much appreciated!
my 90 Bronco 351w dos the same thing every once and a wile drops between N and the O but it normally gives a reading between the "R" and the "M" than after a few starts or some times wal i am driving it gos back to were it is normally i am sick of it i am just going to put a auto meter gauge in it and i have replaced the oil pressure sending unit still dos the same thing.
Guys I may be wrong about this, but I remember hearing on "Cartalk" a few years ago that the factory oil pressure gauges on Ford trucks during the early and mid 1990's were not truly displaying oil pressure, the gauge just activated when the motor started and would sit somewhere in the middle (between the "R" and "M"). Can anyone else confirm or deny this?
I do not have the oil pressure guage on the inst. cluster but I do have an aftermarket guage. I have an 83 351w and after its wormed up it idles at about 50 psi.
For some reason right after I got a timing cover leak fixed the pressure after being on the highway for a bit (and sometimes randomly) will drop to 20psi at idle but will go back up once i touch the gass.
I was told that 20psi is normal at idle and a mechanic told me that the older 351's only need 7psi to run alltho another mechanic said that sounded a bit low.
As for the 90's trucks only having a warning guage kinda makes sence. You know how Ford and there infinate wisdom is.
If you are worried about it get a mechanical guage or the part 91F-150302 is talking about.
I'm thinking it might have something to do with oil temp and/or viscosity maybe. When I first start my truck up after sitting a while it goes to the "R" now, but after driving it for a bit it goes back down to the "O" or between the "O" and the "N". Also, the colder it is when I start my truck, the higher the reading is. I know that when things are warmer, they are less viscous (usually) which means they flow easier which would mean less pressure. I may be way off here and may be reading to much into my oil pressure readings, but it just kinda seemed to make sense. But I wouldn't know what could be wrong except for switching to a more viscous oil, but I don't remember it being too much of an issue in the past. I will look into getting a better gauge, too.
