Wanna remove my smog equip
I wanna get rid of all the smog crap under the hood. I don't think it will give me any power but it will sure help clean up the engine compartment. Just wondering if anyone has done this and if it will cause me ill wanted side affects.
I have a 92' f150, 4x4, aod, 5.0, no cats.
good idea! might as well throw that EFI crap away and bolt on a carburetor too.....make an adapter plate.....and i'd definitely toss the electronic ignition and put in a points type distributor. If you can find a 1968 f100 at the junk yard you could also upgrade to the non power assist front drum brakes. Good luck!
Helpful post Kevin! I have though about just trading up to a bicycle also.
I have also thought about removing the smog pump on my '88 5.0. Does your truck pass inspection with no cats? I'm getting my truck inspected tomorrow and will ask them. I think mine are clogged up since my MPG is down and I have 191,000 miles.
I think removing the pump and shortening the belt by only about 2-3" would do the trick. I know Jeg's has an idler pully to replace the smog pump and keep the stock belt. This idler was made for the Mustang 5.0 so I am not sure if it would fit our trucks.
well i dont think you would clog up your cats with no airpump....my OTHER ford ( 90 thunderbird SC ) has no air pump from the factory.....no EGR either for that matter......and the cats don't clog up...... but my question is .... WHY?...what will you gain from taking all this stuff off? nothing!...
I'd leave it alone, too.
ok well i'll buy the possibility of a different kind of cat then, because my Tbird did not have an airpump from the factory yet it does have 2 catalytic converters. i definitely would not remove an airpump from a vehicle that has one, first of all, what's the point?....and secondly, everything is designed to work as a system...removing one part of that system probably isn't a good idea.
Man you guys didn't read my post! I have no cats and am not looking for any power gains. I also have BBK headers, true duals, ported heads, crane cam, blah blah blah. I just wanted to clean up the engine compartment a little. I would not take off the pump, just leave it, removing will not make any power. I am looking for whatever problems I may run into. Thanks
Oh yeah, I live in Alabama, no emissons test, no vehicle inspections. We are about 50 ys behind the rest of the states exept Miss.
And I already have a bicycle
And an old 76 torino with front drum brake, you can stand on the ground between the engine and fender and tune the carb. It's great
So far I havn't read one post that is fully correct, so I'll try and answer it from my experience.
First off, the smog pump has nothing to do with the engine going into open/closed loop. That is strickly controled by the ECM, and the last time I checked there was no electronics on the smog pump. Yes, there is the TAB and TAD, but as long as those are hooked up, everything runs fine.
You will need a shorter belt with the smog pump gone and plug off a couple miscelaneous vac lines, but i've noticed it really cleans up the engine compartment. However, if your looking for any powergains this is a waste of time unless your pump is siezed.
Like mentioned above, if you remove the smog pump, and not the cats, they will clog, garranteed. Since you don't have them, go ahead and rip that smog pump out. It is actually doing NO good being in there with your cats removed. They (smog pump and cats) work as a team, not independant, to make the exhaust cleaner. If you remove either one, the system no longer works.
All that you really need to keep these pre OBD-II engines running right is the PCV valve (just common sense) and the EGR. Other than that, I have all of the emissions stripped off of my truck. The EGR is the only one that can affect how the ECM thinks.
