04-15-2003, 09:19 AM
Ground wire???
For the '95 truck in the sig:
I had an issue a while back with some poor workmanship at a local dealership, and I just found something else that they did not put back right.
What is the purpose of the braided ground wire that connects from the passenger side firewall to the intake manifold? They just left it on the wheel well and put a regular bolt in the air pump hose bracket.
Thanks for the input,
Bill C.
'95 F-150 XLT SuperCab, 351, 4x4, E4OD
'88 Ranger, Reg. Cab, 2.3, 5sp O/D
04-15-2003, 11:29 AM
1996 Ford F-150
Vehicle: 1996 Ford F150
It grounds the cab. remember it's mounted on isolators which may not allow a good ground.
04-15-2003, 01:39 PM
Garage is empty, add now
Vehicle: 1992 ford f150
Yeah, need to hook that baby back up
04-15-2003, 10:43 PM
Vehicle: 1992 Ford F-150
Your truck has redundant grounds so in the short term it won't cause a problem. Eventually though when other grounds start to corrode it can cause electrical problems. I usually forget a couple grounds when i replace engines or head gaskets (new vehicles have about 15 different ground wires to the engine) but i try to look everything over and find everything i miss before i give it back to the customer.
-Jon
04-15-2003, 11:35 PM
Vehicle: 1988 Ford Bronco II
Ok just time "shime" in here but why does my '88 B2 have a ground strap from my passenger hood bolt to the fender? It snapped and wonder if there is any real reason I should put a new one on? Doesn't seem like it would matter.
04-16-2003, 08:01 AM
1996 Ford F-150
The underhood light may not ground properly thru the hinges, the cable assures a ground.
04-16-2003, 05:03 PM
funny things B2s don't have underhood light...
04-17-2003, 09:32 AM
Back together now, no immediate changes as far as I can tell.
Bill C.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
