Bad starter relay or starter?
Hello all. Went out to my 96 1/2 ton big 6 standard shift today and turned the key only to hear a single loud click. The click is coming from the starter relay on the passenger side fender next to the battery. I jumped the relay to try and start the truck and it still just clicked...sounded pretty loud and you could feel the click on the fender. My question is, bad relay or bad starter/solenoid? A new starter/solenoid and relay will be here in the morning. How tough is the starter to replace? It looks like I have plenty of room to work. Any tips or tricks would be greatly appreciated! Thanks in advance.
Randall
Randall
For the starter. It's on the passenger side hooked to the tranny bell housing. I just replaced mine and it took all but 10 minutes. If it's clicking then that would mean it's getting power and it's working fine, unless it's just like one click.
I had a problem where I would turn the key and it would just click over and over again, well it turned out being a wire that's clips to the starter had a dirty contact and would just slightly jiggle off so i would have to crawl under there and push it back on, eventually I just replaced the wire altogether and have had no problems since.
