where is the ECT sensor??
Old 01-24-2003, 05:36 PM
bw99's Avatar
where is the Engine control temperature sensor in a 93 f-150, 300 I-6, about how much do they cost? and what things happen when they start to go bad??? Thanks in advance
Old 01-24-2003, 05:42 PM
StrangeRanger's Avatar
Center front top of engine on the thermostat housing.
When they start to go bad, they cause the engine to run rich.
Old 01-24-2003, 08:13 PM
SPROCKET_X's Avatar
I just got one from the dealer a few months back, I can't remember the price but it wasn't to expensive..under $20.
Bring in the old one or get the part # off of it becuase my dealer couldn't find the # in the computer.
Old 01-24-2003, 08:18 PM
SPROCKET_X's Avatar
crap nevermind I just found the reciept. It was $29.80 Part # F2AZ12A648A
Old 01-24-2003, 09:41 PM
bw99's Avatar
is there a easy way to tell if it's running rich, except for poor fuel economy? pardon my ignorance, I'm not what you would call mechanically inclined...but I'm learning slowly
Old 01-24-2003, 11:07 PM
Ford4ever's Avatar
Sometimes you can tell by what the spark plugs look like, otherwise you would need to check the voltage output of the o2 sensor.
If you check in a repair manual they should give a spec for the resistance through the sensor. It you find that it is open or shorted then you definitely need to replace it.
-Jon
Quick Reply: where is the ECT sensor??
