03-09-2010, 10:20 PM
whats the most you'll put your 2wd in?
http://www.youtube.com/watch?v=_ypRNbGBxq4
in that video at about 2:45 is the kind of mud we have around our cane fields around here...except it is around the WHOLE field instead of just 10 feet of it haha. would you think an open 4x2 with mud grips could make it through??
1999 F250LD- 4x2 Tan XL Extended Cab-4.6L V8-3.73 Rear Axle-40% Front Tint-1% Rear Tint
Future Mods:
1.5" Daystar Leveling Kit
285/75-16 Maxxis Buckshot
3" Body Lift
Rear Limited Slip/Locker Diffy
SI-DO Exhaust System
Black Toolbox
03-09-2010, 11:31 PM
Garage is empty, add now
Vehicle: 2003 Audi A4 Quattro
Nope not a whole field. A 10ft patch sure.
--Dave--
2003 Audi A4 Quattro 1.8T 5-speed Mods: Test Pipe and 2" Lowered. Soon to come, chipped to 20psi.
2001 Supercrew XLT 5.4L 4x2 - Totaled
03-09-2010, 11:36 PM
2005 Ford F-150
Vehicle: 2005 Ford F150
Only one way to find out. Bring a buddy with 4wd or a tractor of some sort.
03-10-2010, 01:02 AM
Mosh it until it will mosh no more, then call for a recovery
03-10-2010, 11:33 AM
i've put my 2wd in lakes, ponds anywhere i dont really care. I'll drive through it
2007 Regular Cab 2wd
6" Fabtech
ProComp 1069 Wheel's
35x12.5x17 Maxxis Bighorn's
4.56 Gears
SCT Livewire
03-10-2010, 06:37 PM
how much would a rear locker help in this type of instance?
Future Mods:
3" Body Lift
Black Toolbox
03-10-2010, 06:42 PM
a locker would help a lot in certain instances, but you should have a 4x4 with you. Driving skills pay off a lot too.
6" Fabtech
4.56 Gears
SCT Livewire
03-12-2010, 04:53 PM
Vehicle: 2000 Ford F-150
Quote:
A true locker like a detroit, not just a limited slip, 4.10s for more torque from the 4.2, and real mud tires-intercos, not some street mud terrain, aired down to about 15psi and Id do it.
With a 4x2 momentum is your friend, after you run out of momentum its traction, that’s where the locker, and low psi real mud terrains come in.
2000 F-150 XL 2wd 4.2L, 5.5" front 3" rear lift, Bilstein 5100s all around, 33" General Grabber AT2, 130w KC Daylighters, Dual 4' Firestiks-Sig by screenfx
03-13-2010, 12:24 AM
2010 Ford F-150
Vehicle: 2010 FX4 Screw
Just keep moving...and yes to the locker and some aggresive tires
heres my old 2wd screw (lifted and 33 all terrains) i have followed lifted 4x4 jeeps thru some nice size mud holes, then turn around and get stuck quick as chit on soft sand. (p.s. note the new screw)
2010 FX4 Screw 6.5ft bed
6in BDS lift, 35x12.50 Open Country's and 18in D1ck Cepek rims
Bakflip F1 and Bedrug, Front Windows Tinted, HD Tails
Catback duals, 4in stainless rolled tips.
03-13-2010, 11:32 PM
Nope.
But if you try, take a vid and post it here.
B]Thanks Screen FX[/B]
| Full Bolt-Ons Complete minus LT's & tunes |
| mandrel bent true dual straights w/ H-pipe & deleted rear cats |
| ScanGauge II | Factory Tech. Separator Plate | Platinum & Amsoil |
03-13-2010, 11:37 PM
2004 Ford F-150 SuperCrew
Vehicle: 2004 F150 5.4 FX4 Screw
I've never owned a 4x2 but if it's set up, I'll run it through anything.
Gettin stuck's half the fun, ain't it?
:bandito:
03-14-2010, 09:25 AM
2004 Ford F-150
Vehicle: 2004 Ford F-150
I took my truck through 34 inches of water, it made it through once, and stalled the second time.
Thats the only time I have been stuck, stuck. Other than I do fine.
 2002 F-150 4.2 - MAC Intake - True Dual Exhaust - 3/2 Procomp Lift - Procomp ES3000's - 3.73 LSD - 285/75/16 Nitto Terra Grapplers
03-16-2010, 12:40 AM
i'ld hit it... and get through it just fine. its the part where he got stuck near the end i wouldnt venture through!
03-16-2010, 04:18 AM
2001 Ford F-150
Vehicle: 2001 F150
ill try anything
"this truck comes loaded with a sunroof and seat heaters"
"sounds great! let me just put on a dress and hop on up! "- Hank Hill
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
