Broken Diff. Pinion Shaft Retaining Bolt
(2004 F150 XL 2WD)
The head is off my pinion shaft retaining bolt. This was discovered by my mechanic, who got scared and promptly replaced the cover. Trouble is, I do need rear axle seals, so has anyone suggestions on how to extract this bolt?
Phil
Photo shows an intact bolt:
Phil
Thats a toughy. If you get a reverse cut drill bit and try to drill it out, it might work, or use an EZ out. It must have been installed with an impact wrench to wring off the head. It doesn't need to be torqued very much. Good Luck! PS I've broken off EZ outs before so I'm leary of using one.
Yeah, the center section may have to come out to repair it. But, you can't take it out with that bolt stuck!!!!! I suggest taking it to a 4x4 shop that is used to setting up differentials and get them to replace the seals. After talking to a 4x4 shop or other good shop, depending on how confident they are in their ability to get that bolt out, it may be easier to get a used complete rear axle from a salvage yard and chang out the whole thing.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
Spend the money and buy a good quality LH bit from MSC or Grainger or another reputable industrial supplier, Don't trust Amazon or Home Depot or Harbor Freight.
A GOOD welder might also be able to weld another bolt to that one and you could then unscrew it.
I imagine you have gotten this taken care of by now, but if not...
While the bolt may be 1.5" long, only the first half inch of it is threaded. It also has lock-tite on it from the factory.
With the head broken off, the rest of the bolt is no longer under tension and will back out easily - ONCE the loc-tite has been heated up and rendered it's binding properties useless. Use a pick to turn it, or a LH drill bit.
If that fails, you could drill through the end of the cross pin where the stub part of the bolt goes through, essentially drilling the locking bolt in half. That would allow the carrier to come out and be the removal could be performed at a machine shop.
